Sigma AF 17-70mm f/2.8-4.5 DC (Nikon) - Review / Lab Test Report - Analysis |
Typical for many standard zoom the Sigma lens produces a pronounced degree of barrel distortion
at 17mm (~3%) changing to slight pincushion distortion when zooming towards 70mm (~0.45%). At
about 35mm both forces even out so the lens shows basically no distortion here.
17mm |
35mm |
70mm |
Standard-zoom lenses with a reduced image circle tend to vignette quite a bit specifically
towards the wide end of the zoom range. This is also true for the Sigma AF 17-70mm f/2.8-4.5 DC.
At 17mm the level of vignetting is pronounced with ~1.2EV at f/2.8 but stopping down to f/4
reduces the problem to a manageable degree. At 35mm the issue is very well controlled
whereas the vignetting increases again at 70mm (0.83EV @ f/4.5).
The Sigma AF 17-70mm f/2.8-4.5 DC produced quite a mixture of quality levels in the MTF lab.
At 17mm the center performance is excellent straight from the max. aperture. The borders
are very good but the extreme corners are soft at f/2.8 and to a lesser degree also at f/4.
Stopping down to f/5.6 resolves some of the corner problems but the peak performance
is not reached prior of f/8 (very good corners). The sweet spot of the lens is at 35mm - the
resolution is already evenly high at f/3.8 and outstanding from f/5.6 onwards. This is a
surprising level for a standard zoom lens. There's a slight drop in resolution at 70mm but
the quality remains easily very good at f/4.5 and excellent from f/5.6 (and that's despite a
slight centering defect here).
The Sigma manages to keep lateral chromatic aberrations (color shadows at harsh contrast
transitions) very well controlled for a zoom lens. The problem is a bit more pronounced
at 17mm @ f/2.8-4 with an average width of ~1.1px at the image borders. However,
stopping down to f/8 reduces the CAs to a very good level. Typical for most standard zooms the
problem decreases when zooming towards longer focal lengths.
The Sigma AF 17-70mm f/2.8-4.5 DC is a very good standard zoom and a viable alternative
to the Nikon offerings in this range. Generally it is capable to produce very sharp
results although the corner performance leaves a bit to be desired at 17mm at large aperture
settings. The vignetting level could also be a bit better here but most competitors
don't offer a f/2.8 settings anyway and from f/4 it follows the mainstream. The level of
distortions is about typical for a standard zoom whereas chromatic aberrations (color shadows)
are comparatively low. The build quality is very fine for a lens in this price league.
