Pentax DA 12-24mm f/4 AL ED [IF] - Review / Test Report - Analysis
The Pentax DA 12-24mm shows a pretty good distortion characteristic for an ultra-wide zoom lens. At 12mm there's a relatively pronounced degree of slightly wavy barrel distortion (~2.1%) which decreases continuously when zooming towards the long end of the zoom range where the lens is basically free of distortion.
12mm 18mm 24mm
At 12mm @ f/4 the lens shows fairly strong vignetting (~1.1EV) which will be visible in some scenes. However, from f/5.6 onwards the problem is already largely reduced and generally harmless in field conditions. At 18mm and 24mm the amount of vignetting is far less pronounced even at wide-open aperture.
The Pentax produced pretty impressive resolution figures in the MTF lab. Unlike many other lenses with a reduced image circle it is capable to combine a generally excellent center performance with very good borders as well as very good extreme corners. The center performance decreases slightly when zooming towards "longer" focal lengths whereas the border quality remains more or less constant. The contrast is slightly reduced at 24mm @ f/4 but it's already fine when stopped down to f/5.6. The field curvature is quite moderate.
CAs (color shadows at harsh contrast transitions) are the primary weakness of the Pentax lens (just like in the Tokina variant). At 12mm and 18mm CAs peak way beyond 2px on the average at the image borders. Stopping down helps to reduce the problem but it's still high at f/8. At 24mm the situation eases somewhat.
Please note that CAs can be largely corrected via imaging tools such as Adobe Photoshop.
