Pentax SMC-FA 20mm f/2.8 - Review / Test Report
The Pentax SMC-FA 20mm f/2.8, a full format lens, is discontinued by now but it may be interesting to have a look how it compared to the current SMC-DA 21mm f/3.2 Limited. When used on APS-C DSLR the FA 20mm f/2.8 has a field-of-view equivalent to 30mm so it leaves its original ultra-wide scope towards a mainstream wide-angle.
The build quality of the lens is fine but nothing to rave about either. Subjectively the plastic quality could be a little better. The small rubberized focus ring operates very smooth. The lens extends a tiny bit when focusing towards closer focus distances. The front element does not rotate so using a polarizer is not a problem.
The lens has no internal AF motor and relies on a slotted drive screw operated by the camera. As a result AF operation will generate a moderate degree of noise. The AF speed is very fast on the K10D.
Equiv. focal length30 mm (full format equivalent)
Optical construction10 elements in 9 groups
Number of aperture blades6
min. focus distance0.25m (max. magnification ratio 1:8.3)
Dimensions70x44mm
Weight255g
Filter size67mm (non-rotating)
Hoodoptional
Other features-
Pentax DA 21mm f3.2 SMC AL Limited Lens #668
Auction price: 206.15 USD
Condition: Used
Time left: 17d,4h,18m
Accepts Paypal: NO
Pentax SMC DA f/3.2 21mm AL Limited Wide Angle Lens Japan [Exc+++] #2275883A
Auction price: 204.55 USD
Condition: Used
Time left: 9d,15h,11m
Accepts Paypal: NO
PENTAX HD DA21mm F/3.2AL Limited Silver -Near Mint- #305
Auction price: 282.00 USD
Condition: Very Good - Refurbished
Time left: 29d,19h,19m
Accepts Paypal: NO
SMC PENTAX DA 21mm f/3.2 AL Limited Wide Angle Lens [Near Mint] from Japan F/S
Auction price: 224.99 USD
Condition: Used
Time left: 27d,2h,34m
Accepts Paypal: NO
