Zeiss Makro-Planar T* 50mm f/2 ZF (ZE) (on Canon EOS) - Lab Test / Review - Analysis |
Canon EOS (Full Format)
The Makro-Planar produces only a slight degree (~0.8%) of barrel distortion which isn't really
field relevant anymore.
The Makro-Planar may not be as fast as a conventional standard prime lens but it suffers
from a similar amount of light falloff at max. aperture (2.2EV). The vignetting is still
visible at f/2.8 and you've to stop down to f/4 in order to resolve the issue.
Macro lenses tend to be great performers and the Zeiss is no exception
to the rule. At wide-open aperture the lens is already extremely sharp in the
center whereas the borders/corner are a little softer but still in very good territory (just).
The quality increases gradually the more you stop down and the global peak is reached
around f/5.6 with an excellent center-to-edge quality. Diffraction is the limiting factor beyond
f/8 so even Zeiss cannot fool physics. However, the results are still usable even at f/22.
The Makro-Planar produces a very minimal amount of lateral CAs (color shadows at harsh contrast
transitions). This is not field relevant and an excellent performance in this category.
The quality of the bokeh (out-of-focus blur) is naturally a major aspect for a macro lens. The Zeiss lens
does a very good job here. The inner zone of out-of-focus highlights is very evenly rendered. However, the
discs deteriorates to a "cat's eye" shape at large apertures which is less pleasing than the circular
shape (which is achieved at smaller apertures). The blur in the focus transition zones is very smooth.
There's a some bokeh fringing (greenish/purple halos in the focus transition zone) at f/2 but it's not overly disturbing.
The issue is somewhat resolved at f/2.8 and not really relevant anymore from f/4 onwards.
| f/2 |
f/2.8 |
f/4 |
Just like the rest of the Zeiss Z-series the Makro-Planar 50mm f/2 is not a
lens for mainstream users due to the lack of AF. However, to put things into
perspective - AF is not a killer feature for macro lens anyway but then you may
also argue that its very large max. aperture may be sufficient to substitute a
conventional 50mm lens.
Quality-wise it's an impressive lens offering a very high resolution till
diffraction takes its toll. Lateral CAs are basically non-existent and
the little amount of barrel distortion is not field relevant.
At f/2 there's some vignetting which can be disturbing in some scenes so
you should either stop down or resolve the issue during image
post-processing. The bokeh (out-of-focus blur) is generally very smooth and
buttery.
A comparison to competing macro lenses is a little difficult. On the upside the
Zeiss is a full stop faster than but on the other hand the max. object magnification
is "just" 1:2 which may be a somewhat limiting factor for macro enthusiasts (that's
also true for the Canon EF 50mm f/2.5 macro though). So you gain and loose a little in
terms of flexibility. The price tag is comparatively steep at around 1100-1200€/US$
so you really have to have an itch for such classic lenses.
