Nikkor AF-S 16-35mm f/4 G ED VR (FX) - Review / Test Report - Analysis
Ultra wide angle lenses usually show a considerable amount of barrel distortion, but it's a little surprising that the AF-S 16-35 VR shows even more of it at the wide end than the AF-S 14-24. A slight amount of barrel distortion is still left at 21 mm while at 28 mm and 35 mm there is some pincushion distortion at close to 1 %.
Especially at the short end, that's fairly hefty, however the good news is that at any focal length distortions are uniform and can easily be corrected by software in post processing (at the expense of resolution and a little field of view, of course).
16mm 21mm 28mm 35mm
At the wide end, the lens produces visible vignetting even stopped down, but at all other focal lengths vignetting is well controlled for a wide angle zoom lens. Wide open it can be visible and disturbing, however slightly stopped down the amount of light falloff left is usually not field relevant anymore.
Let's start with the good news: stopped down to f/5.6, the lens produces excellent resolution figures in the center at any tested focal length. This is also true for wide open aperture at 16 mm, but at any other tested zoom setting the resolution is one mark lower, still very good, though.
At 21 mm and 28 mm, the borders and extreme corners also can reach very good resolution figures if the lens is used stopped down.
At 16 mm and 35 mm, though, the corners and borders fall considerably behind. At 16 mm, the corners wide open only show poor sharpness, but at least considerably stopped down sharpness recovers to a good level, the border sharpness even is very good from f/5.6 onwards. At 35 mm, both borders and corners show good resolution, almost regardless of the chosen aperture. Stopping down does not significantly increase sharpness here.
Chromatic aberrations (color shadows at harsh contrast transitions) are in the range of roughly 1 pixel at the image borders throughout most of the focal and aperture range. Only at 16 mm the amount of CAs is a little higher with up to 2 pixels wide open.
