The lens shows a small amount of barrel distortion that is hardly field-relevant.
Fast lenses tend to suffer from high vignetting on full frame cameras and the AF-S 85/1.4 is no exception to this rule. Wide open the corners darken visibly with a maximum light fall-off of almost 1.8 EV. Stopping down helps to reduce vignetting, but even at f/2 the amount of light falloff remains on a level that can be disturbing. From f/2.8 onwards vignetting is no longer field-relevant, except for really critical scenes.
The center resolution is excellent straight from the maximum aperture and reaches extremely high figures stopped down to f/4.
Borders and corners follow a bit behind with very good resolution wide open. Stopping down helps to increase the resolution to excellent sharpness from f/4 onwards.
For such a fast lens this is an impressive performance. Unfortunately there is one issue that spoils the party a little bit: the lens showed a slight amount focus shift when stopping down (residual spherical aberration).
Chromatic aberrations (color shadows at harsh contrast transitions) are well controlled. They reach a maximum amount of 0.9 pixels on the average at the image borders at f/2, but decrease again by stopping down.
As you'd expect from a fast portrait lens the quality of background blur is in a very high level. However, there's a tad of nervousness, especially in the transition zone. Stopping down slightly helps to reduce the issue, though.
Thanks to 9 rounded aperture blades, background highlights retain their circular shape throughout the whole aperture range, except towards the image corners. Due to mechanical vignetting they are cut off at one side at wide open and to some degree also at f/2. There is a small amount of outlining and some traces of Bokeh fringing (which is typical for this lens class, see next section).
and green beyond.
Typical for most fast primes, especially ultra fast ones, the AF-S 85 shows noticeable bokeh fringing at large aperture settings, which can of course be reduced by stopping down.
f/1.4 |
f/2 |
f/2.8 |
f/4 |
f/5.6 |
