Nikkor AF 180mm f/2.8 D ED (FX) - Review / Test Report - Analysis
The lens shows a small amount of pincushion distortion, that may be visible in subjects with straight lines towards the image borders, but should not be an issue with the majority of subjects one usually shoots with a fast prime lens (like portraiture).
Vignetting is well controlled for a f/2.8 FX lens. There is a moderate amount of light fall-off towards the corners wide open. Stopped down, vignetting is reduced to lower and for most subjects irrelevant levels.
The lens shows excellent resolution in the image center wide open already and remains on this high level down to f/8. At f/11 (and beyond) diffraction takes its toll and significantly reduces resolution again.
The borders and corners follow one step behind with very good resolution across the tested aperture range, except for the extreme corners, that stay just a bit below this level wide open and at f/11.
Chromatic aberrations (color shadows at harsh contrast transitions) are very low and well controlled wide open, but increase to slightly higher levels when stopping down. However, CAs can easily be corrected in software or by the camera itself (most modern Nikon DSLRs remove CAs themselves if you shoot JPGs).
The background blur shows some signs of nervousness in the transition zone from in-focus to out-of-focus, but apart from that is generally quite smooth.
Background highlights show only a very small amount of outlining and are actually well rendered. However, they are slightly cut off towards the image borders due to mechanical vignetting and start to lose their circular shape at apertures of f/5.6 and smaller. In addition, there's a visible amount of bokeh fringing (green outlines, see next section).
Typical for most fast primes the AF-D 180 shows noticeable bokeh fringing at large aperture settings, which can of course be reduced by stopping down.
f/2.8 f/4.0 f/5.6 f/8.0 f/11
Flare/Glare
The lens does not really like backlight and visibly loses contrast across the whole image in these conditions. In addition to the glare, there are also traces of soft flare spots, but depending on the subject they may not be visible at all. IN the sample image below, you can see a green haze spot close to the lower border of the image.
