The lens shows a moderate amount of barrel distortion which can be visible in critical shots especially with straight lines near the image borders. However, the distortion is uniform and easy to correct in post processing.
Fast lenses tend to suffer from high vignetting on full frame cameras and the AF-D 28/1.4 is no exception in this regard. In fact, with just above 2.1 EV wide open the light fall-off towards the image corners is very pronounced and of course clearly visible in the final image (see the sample image section on the next page for examples). Stopping down helps to reduce vignetting, but even at f/2 the amount of vignetting remains rather high. From f/2.8 onwards vignetting is no longer relevant, except for really critical scenes.
The center resolution is very good already at the largest aperture. However the lens shows reduced contrast at this aperture setting as well as what is often described as "glow" around contrast edges. This behaviour is typical for many classical ultra-fast lenses. Stopped down, the resolution (and contrast) increases and reaches excellent level from f/2.8 onwards.
The borders and corners follow one step behind, with good resolution wide open and moderately stepped down. From f/5.6 onwards the resolution reaches very good values here. Surprisingly, the extreme corners always performed slightly better than the image borders throughout the tested aperture range.
Chromatic aberrations (color shadows at harsh contrast transitions) range from abive 1.5 to almost 1.9 pixels at the image borders throughout the tested aperture range. This might be visible in very large prints (or crops). However, CAs can easily be corrected in software or by the camera itself (most modern Nikon DSLRs remove CAs themselves if you shoot JPGs).
In front of the focal plane the bokeh is quite smooth, however for most real-world shots, especially with a wide angle lens, that's mostly irrelevant. The more important area behind the focal plane shows a rather nervous blur characteristic.
Background highlights show a cat's eye shape due to mechanical vignetting at the largest aperture, which is typical for fast lenses. In addition, there's a fair amount of outlining, which increases the impression of nervousness. Stopped down, the outlining is reduced, but the shape of the aperture blades becomes visible.
Bokeh fringing (non-coinciding focal planes of the various colors) is a common issue with relatively fast glass. As you can
and green beyond. Truly "apochromatic" lenses don't show this kind of fringing but these lenses are very rare especially
below 100mm. Unlike lateral lateral CAs, bokeh fringing cannot easily be fixed in post processing.
Typical for most fast primes, especially ultra fast ones, the AF-D 28/1.4 shows some amount of fringing at large aperture settings, which can of course be reduced by stopping down.
In addition, these shots show the "glow" around contrast edges as well as the lack of contrast at large apertures (which is pronounced in these images due to the very short focus distance) as already mentioned in the MTF section.
| f/1.4 |
f/2 |
f/2.8 |
f/4 |
f/5.6 |
