Tamron AF 17-35mm f/2.8-4 Di SP (FX) - Review / Test Report - Analysis
The lens shows a significant amount of barrel distortion at the shortest focal length, which decreases by zooming in. At around 28mm the lens is basically free of distortion. Zooming in further, the distortion changes to the pincushion type, but remains moderate.
17mm 21mm 28mm 35mm
For a wide angle lens, the Tamron is quite fast and so it’s not really surprising that the lens shows some vignetting. This is especially true at 17mm, where the light fall-off towards the borders reaches an amount beyond the scale of our graph. Stopping down eases the issue slightly, but even at small apertures there is still one stop ov vignetting left.
The behaviour is similar at 21mm, but with a slightly lower amount of vignetting.
Zooming in further, vignetting is no longer really an issue, at least at medium apertures an beyond.
Let’s start with the good news: the center resolution of the lens is very good wide open and excellent stopped down at all tested focal lengths.
The borders and extreme corners are a very different story, though. At large apertures, the borders and especially the corners are quite soft. The lens needs to be stopped down to produce acceptable sharpness here. However, at around f/8, it is able to produce at least good sharpness across the whole frame.
Lateral CAs (color shadows at harsh contrast transitions) are quite pronounced, reaching peak values of almost 3 pixels at the image borders.
