Sony 50mm f/1.4 ( SAL-50F14 ) - Review / Test Report - Sample Images & Verdict
Here're some sample images taken with the Alpha 700 and RAW-converted via CaptureOne 4.1. Sorry for the rather mediocre quality but the weather was dismal at the time of the review.
Make SONY
Model DSLR-A700
Focal Length 50.0mm
Exposure Data: f/8.0 @ 1/250s
Size 4272x2848
Make SONY
Model DSLR-A700
Focal Length 50.0mm
Exposure Data: f/1.4 @ 1/500s
Size 4272x2848
Make SONY
Model DSLR-A700
Focal Length 50.0mm
Exposure Data: f/1.4 @ 1/800s
Size 4272x2848
Make SONY
Model DSLR-A700
Focal Length 50.0mm
Exposure Data: f/1.4 @ 1/1600s
Size 4272x2848
Make SONY
Model DSLR-A700
Focal Length 50.0mm
Exposure Data: f/2.0 @ 1/1600s
Size 2848x4272
Make SONY
Model DSLR-A700
ISO Speed 320
Focal Length 50.0mm
Exposure Data: f/2.0 @ 1/400s
Size 4272x2848
The Sony 50mm f/1.4 is a typical representative of the standard lenses that were designed back in the 70s to 80s. The max. aperture (f/1.4) should be generally avoided due to weak contrast, poor borders and a significant amount of longitudinal chromatic aberrations (LoCA). The image quality is already vastly improved at f/2 including a technically better (smoother) bokeh. The truly excellent peak performance is reached around f/4. As to be expected neither distortions nor vignetting are real issues but lateral CAs could be lower for a fix-focal length lens.
The build quality is pretty decent and the conventional screw-driven AF is very fast although somewhat dated regarding Sony's SSM (supersonic motor) ambitions. At around 320€/US$ the lens is priced at the upper end compared to the other major brands - maybe some food for thought over at Sony.
