Here're some sample images taken with the Alpha 700 and RAW-converted via CaptureOne 4.1.
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/2.2 @ 1/640s
Size
2848x4272
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/2.8 @ 1/1600s
Size
2848x4272
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/1600s
Size
2848x4272
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/640s
Size
2848x4272
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/1250s
Size
4272x2848
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/5.6 @ 1/400s
Size
2848x4272
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/2000s
Size
4272x2848
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/500s
Size
2848x4272
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/640s
Size
4272x2848
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/400s
Size
4272x2848
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/640s
Size
4272x2848
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/1600s
Size
4272x2848
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/800s
Size
4272x2848
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/4.0 @ 1/400s
Size
2848x4272
Make
SONY
Model
DSLR-A700
ISO Speed
200
Focal Length
135.0mm
Exposure Data:
f/1.8 @ 1/800s
Size
4272x2848
The Zeiss Sonnar T* 135mm f/1.8 ZA is an exceptional lens - technically it's even slightly superior to the already great ZA Planar T* 85mm f/1.4. The resolution as well as the level of contrast is nothing short of outstanding and that's straight from f/1.8. The quality of the bokeh (out-of-focus blur) is next to perfect for a conventional lens. Unfortunately longitudinal CAs, sometimes also called "Bokeh CAs", can be relatively pronounced at large aperture settings - a typical problem in this lens league but a bit unfortunate nonetheless. Distortions, vignetting and lateral CAs are non-issues in field conditions. Thanks to an all-metal body the lens feels very solid. If you're nit-picky
you may criticize the lack of sealing and a little play in the focus ring when changing the focus direction. The AF
speed is still fine despite the rather dated screw-driven AF approach. The entry hurdle for the Zeiss T* 135mm f/1.8 ZA is quite high at around 1300EUR/US$ but if you want the very best this is the one. Highly recommended!
