Sony 30mm f/2.8 DT macro ( SAL-30F28 ) - Lab Test / Review - Analysis |
The Sony lens produces a slight to moderate amount of barrel distortion (~1.2%). This is usually not relevant in field conditions unless you're intending to use the lens for repro work (which is a typical application for macro lenses).
The 30mm f/2.8 covers the APS-C image circle only so it produces a comparatively high amount of vignetting. At f/2.8 it exceeds 1.5EV which can be critical in some scenes. Stopping down to f/4 resolves the worst part but you need to stop down to f/5.6 to eliminate the problem altogether.
The Sony lens delivery very good to excellent resolution results during our MTF tests. The center performance is already excellent straight at f/2.8 and the borders/corner follow on a very good and good+ level. The performance peak is reached around f/5.6 with an excellent image quality across most of the image. Diffraction effects start to have a higher impact beyond f/11 but f/16 remains perfectly usable. Except some softness at f/22 but that's normal at such settings and the Sony 30mm DT is better than most here. The tested sample showed a slight centering defect at f/2.8.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are very low at large aperture settings but the issue worsens the more you stop down. It's getting more obvious beyond f/8 but it does never reach overly critical levels.
Out-of-focus highlights show a strong outlining effect as well as a vignetting effect (cat's eyes) at very large apertures. This improves when stopping down to f/5.6 which is rather "late". The blur in the critical focus transition zone is pretty smooth and buttery. All-in-all a mixed bag here.
Bokeh fringing, also called "LoCAs", is a color fringing effect at hard contrasts with purple halos in front and green halos beyond the focus point. The Sony lens shows some bokeh fringing at f/2.8 and a few traces at f/4 but it's certainly no show-stopper.
f/2.8 |
f/4 |
f/5.6 |
The Sony 30mm f/2.8 DT macro ( SAL-30F28 ) shines in many aspects. Like most dedicated macro lenses it is extremely sharp straight from f/2.8 till about f/11 and even f/16 can be considered as a mainstream setting. Lateral CAs are absolutely negligible at large apertures but you may spot them at times at and beyond f/11. The amount of barrel distortion is slightly higher than average for a macro lens but in absolute terms it's still very moderate. Typical for a dedicated APS-C format lens it shows rather heavy vignetting at max. aperture. The bokeh is generally smooth and buttery but out-of-focus highlight show a less than pleasing outlining - possibly the weakest optical aspect of the lens. The bokeh fringing can be just visible at f/2.8 but dissolves soon thereafter.
Just like most of its "DT" cousins it is a budget lens and it shows in its build quality - it is a plastic lens down to the mount. The SAM AF drive struggles somewhat to move the inner tubes throughout the focus range. A focus limiter would have been a good idea here. The AF accuracy is fine though. Possibly the nicest aspect of the Sony lens is its pricing. At less than 200EUR/US$ it's really a steal in relation to its capabilities.
