Canon EF 200mm f/2.8 L USM II - APS-C Review / Test Report - Analysis
As expected for a fix-focal lens the level of distortion is quite negligible. The situation remains about the same when attaching an EF 1.4x II converter.
200mm:
On the EOS 350D with its reduced format (APS-C) the (full format) lens exhibits slight vignetting at f/2.8 which shouldn't be much of a problem even at wide-open aperture. One stop down it is negligible even by lab standards.
The EF 200mm f/2.8 L USM II (2nd sample) exhibited a very decent performance in the MTF lab. At wide-open aperture the resolution is very good and already quite even across the frame. The sweet spot is reached around f/5.6 with an excellent center to border quality.
When attaching a Canon EF 1.4x II converter the quality decreases slightly with good (wide-open) to very-good (medium apertures) ratings - this is based on the 1st tested sample of the lens which performed slightly worse.
The quality of the bokeh (the fore-/background blur at large apertures) is very smooth. The lens isn't overly prone to flare but using the hood is still a good idea especially with streaking light.
Similar to most other fix-focal lenses chromatic aberrations (color shadows at harsh contrast transitions) are extremely low and nothing to worry about.
