Canon EF 28-300mm f/3.5-5.6 USM L IS - Review / Test Report - Analysis
The level of distortion is very well under control for a 10.7x zoom lens. At 28mm distortion is most pronounced with a medium degree of barrel distortion (1.77%). At all other tested focal lengths there is only marginal pincushion distortion (around 0.5%).
28mm:
50mmmm:
100mm:
200mm:
300mm:
As usual you should expect more distortions towards closer focus distances.
The EF 28-300mm f/3.5-5.6 USM L IS is a full frame lens so it can take advantage of a sweet spot effect on APS-C DSLRs and vignetting is indeed almost insignificant. It's most pronounced at 300mm f/5.6 but at 0.5EV it's an ony an issue in very critical scenes.
Regarding its 10.7x zoom ratio the EF 28-300mm L IS is a lens of compromises and regardless of all efforts it cannot be a stellar performer regarding resolution. However, the lens manages to keep the quality on a very respectable level throughout the zoom range. The resolution figures are surprisingly high at 28mm where the center quality is excellent straight from the max. aperture. The border quality follows on a good to very good level without a major gain in quality by stopping down. The sweet spot of the lens is around 50-100mm where the center and border quality is more harmonious. At 200mm and slightly more so at 300mm there's a slight drop in quality but without any unpleasant surprises. Even at 300mm the center is very good at f/5.6 followed by good borders and stopping down lifts the performance a bit further. All-in-all a very impressive performance but naturally not comparable to the best lenses at the respective native focal lengths.
Chromatic Aberrations
Chromatic aberrations (color shadows at harsh contrast transitions) quite well under control for such a lens with a maximum around one pixel of the average at the image borders at the extreme ends of the zoom range.
