Canon EF 70-200mm f/4 USM L IS - Review / Test Report - Analysis
The level of distortion is very low for a zoom lens with a minor degree of barrel distortion at 70mm changing to minor pincushion distortion at 135mm and 200mm.
70mm:
135mm:
200mm:
Vignetting is very well controlled with the lens. At 70mm and 135mm vignetting is quite already negligible at f/4. At 200mm there's slightly more vignetting at f/4 (~0.5EV) - usually nothing to worry about but in extreme situation you may prefer to stop down by a half f-stop to eliminate the remaining artifacts.
The Canon EF 70-200mm f/4 USM L IS is the very best zoom lens tested to date in Canon mount. The resolution figures (center/border) at all focal length and all tested aperture settings are nothing short of stunning and also as good as the best fix-focals in this range. At f/11 there´s the usual decline in quality due to diffraction - this is a physical limit. Truly remarkable.
Chromatic Aberrations
The lens also showed an excellent behavior regarding lateral chromatic aberrations (color shadows at harsh light transitions) peaking around 0.6 pixels on the average at the image borders. This is nothing to worry about by most standards.
