Nikkor AF 28mm f/1.4 D - Review / Lab Test Report - Analysis |
The AF 28mm f/1.4D exhibits only a slight degree of barrel distortion (0.8%).
The AF 28mm f/1.4D is a full frame lens thus enjoying a sweet spot advantage
on APS-C DSLRs. Despite its ultra-large aperture the vignetting is still
moderate at f/1.4. From f/2 onwards the problem is basically negligible.
Unfortunately the Nikkor showed a rather pronounced centering defect (this is a 100% center crop)
which spoiled the MTF results quite a bit specifically at large aperture
settings. Typical for such
defects it helps to stop down and from f/2.8 onwards
the results are very impressive with an extremely high center performance
and very good borders. A fully valid sample should perform even better.
Chromatic aberrations (color shadows at harsh contrast transitions) are relatively
well controlled for a wide-angle lens. At around 1px on the average the problem
can be visible but it's usually no critical issue (and a correctable one anyway).
Regarding the obvious centering defect it is difficult to find a verdict for
the Nikkor AF 28mm f/1.4D. Assuming a valid sample the performance should be
great when stopped down a little. Even in its less than perfect state the
tested sample performed better than the AF 28mm f/2.8. CAs, vignetting and
distortions are very well controlled for a lens in this class. The build
quality is superb. It is a pity that the lens has been discontinued - more so
because Nikon does not offer any replacement nor any other ultra-fast wide-angle
fix-focal AF lens.
Optical Quality: |
not given at this stage |
Mechanical Quality: |  |
Price/Performance: | discontinued |
| What does this mean ? |
