Tokina AF 12-24mm f/4 AT-X Pro DX (Canon) - Review / Test Report - Sample Images & Verdict |
Canon EOS (APS-C)
Ok, finally here're some sample shots taken with the 350D (all converted RAWs via RSE).
Please note that RSE applies some degree of automatic CA correction.
| Make |
Canon |
| Model |
Canon EOS 350D DIGITAL |
| ISO Speed |
200 |
| Focal Length |
20.0mm |
| Exposure Data: |
f/11.0 @ 1/400s |
| Size |
2312x3472 |
| Make |
Canon |
| Model |
| ISO Speed |
400 |
| Focal Length |
12.0mm |
| Exposure Data: |
f/4.0 @ 1/1000s |
| Size |
2312x3472 |
| Make |
Canon |
| Model |
| ISO Speed |
400 |
| Focal Length |
12.0mm |
| Exposure Data: |
f/10.0 @ 1/250s |
| Size |
3472x2312 |
| Make |
Canon |
| Model |
| ISO Speed |
400 |
| Focal Length |
12.0mm |
| Exposure Data: |
f/10.0 @ 1/320s |
| Size |
3472x2312 |
| Make |
Canon |
| Model |
| ISO Speed |
200 |
| Focal Length |
16.0mm |
| Exposure Data: |
f/13.0 @ 1/250s |
| Size |
2312x3472 |
| Make |
Canon |
| Model |
| ISO Speed |
200 |
| Focal Length |
24.0mm |
| Exposure Data: |
f/13.0 @ 1/400s |
| Size |
2312x3472 |
| Make |
Canon |
| Model |
| ISO Speed |
200 |
| Focal Length |
12.0mm |
| Exposure Data: |
f/11.0 @ 1/200s |
| Size |
2312x3472 |
| Make |
Canon |
| Model |
| ISO Speed |
200 |
| Focal Length |
12.0mm |
| Exposure Data: |
f/4.0 @ 1/1600s |
| Size |
2312x3472 |
The verdict about the Tokina AF 12-24mm f/4 AT-X DX can't be easy because its quality varies
across the different characteristics.
In terms of resolution the lens is on a very high level. The center performance is excellent
throughout the whole range. The borders are (naturally) quite a bit worse especially
at f/4 but very decent from f/5.6 onward. Distortions are comparatively low for an ultra-wide
lens and vignetting may only be an issue at 12mm @ f/4.
On the downside chromatic aberrations are a significant problem at harsh contrast transitions - at
least if you perfer straight JPEGs or plain converted RAWs. The problem can be almost completely
avoided by using intelligent RAW converters such as Raw Shooter Essentials or by manual correction
via Adobe Camera RAW or similar tools. So whether this characteristic is a problem for you is
dependent on your workflow.
Beyond CAs the lens doesn't really like contra light. Using the supplied hood is a good idea here
and if possible light sources in the image field should be avoided.
Typical for all Tokina AT-X lenses the build quality is on a very high level putting many lenses
from other manufacturers to shame especially when considering the quite affordable price of about
450 EUR/US$.
