Tokina AF 12-24mm f/4 AT-X Pro DX (Nikon) - Review / Test Report - Sample Images & Verdict |
Ok, finally here're some sample shots taken with the D200 (all converted RAWs via RSP 2006).
Please note that RSP applies some degree of automatic CA correction. These images are test shots and
surely not meant as a piece of art.
Make |
NIKON CORPORATION |
Model |
NIKON D200 |
ISO Speed |
200 |
Focal Length |
13.0mm |
Exposure Data: |
f/11.0 @ 1/320s |
Size |
2613x3898 |
Make |
NIKON CORPORATION |
Model |
NIKON D200 |
ISO Speed |
100 |
Focal Length |
12.0mm |
Exposure Data: |
f/4.0 @ 1/800s |
Size |
2613x3898 |
Make |
NIKON CORPORATION |
Model |
NIKON D200 |
ISO Speed |
100 |
Focal Length |
12.0mm |
Exposure Data: |
f/4.0 @ 1/1250s |
Size |
2613x3898 |
Make |
NIKON CORPORATION |
Model |
NIKON D200 |
ISO Speed |
100 |
Focal Length |
12.0mm |
Exposure Data: |
f/11.0 @ 1/45s |
Size |
3898x2613 |
The Tokina AF 12-24mm f/4 AT-X DX is a lens with many facets. The resolution characteristic is
very good to excellent throughout the zoom range which is quite surprising for an ultra-wide zoom
lens - more so for a third-party lens. Vignetting is very high at 12mm f/4 but quite well
controlled otherwise (for an ultra-wide lens). It produces a fair amount of wavy barrel
distortions at 12mm, less so at 18mm and at 24mm distortions are negligible.
The weakest spot are CAs which are very high at 12mm and 24mm. This
may not be a significant problem for RAW photography because CAs are a correctable problem
but for those preferring JPEGs the issue may be quite annoying at times.
Beyond CAs the lens doesn't really like contra light. Using the supplied hood is a good idea here
and if possible light sources in the image field should be avoided.
Typical for all Tokina AT-X lenses the build quality is on a very high level putting many lenses
from other manufacturers to shame especially when considering the quite affordable price of around
450€/US$.
