Tamron AF 180mm f/3.5 SP Di LD [IF] macro (Nikon) - Review / Test Report - Analysis |
Typical for macro lenses the Tamron shows only an absolutely negligible degree of distortion.
The Tamron is a full-format lens so it can take advantage of the usual sweet spot effect
when used on an APS-C DSLR. Generally vignetting is no real problem even at f/3.5 and
at smaller aperture settings it is a non-issue.
Typical for most macro lenses the resolution characteristic is very impressive.
At f/3.5 the quality figures are already on a very good level. Stopping down
results in a further increase in resolution till reaching an excellent maximum
around f/8. At f/16 the quality is a still on a very good level whereas f/22
suffers from a higher decrease due to diffraction effects (a physical
limitation). f/32 (not shown below) should be generally avoided.
Please note that the MTFs charts below represent the performance near infinity
focus. For the time being dedicated macro performance tests are not possible.
Chromatic aberrations (color shadows at harsh contrast transitions) are extremely well
controlled throughout the tested aperture range. It is a little more pronounced
at f/3.5 but even here CAs are not really field relevant.
