Sigma AF 150mm f/2.8 APO EX HSM macro DG D - Review / Test Report - Analysis |
Macro lenses are renowned for minimal distortion and the 150mm f/2.8 APO EX is no
exception here - the degree of distortion is absolutely negligible.
As mentioned above the Sigma is a full-format lens so the D200 can take advantage
of a sweet spot effect here. At infinity focus and f/2.8 a slight degree of vignetting
may be visible in critical scenes whereas onwards from f/4 the issue is negligible.
At close focus distances the issue is less pronounced even at f/2.8.
Typical for most macro lenses the resolution of the Sigma AF 150mm f/2.8 EX DG HSM APO macro
is excellent straight from the max. aperture setting. The peak performance is reached at f/5.6
with absolutely superb quality figures. All-in-all the Sigma is able to match the performance
of the recently reviewed Micro-Nikkor AF-S 105mm f/2.8G IF-ED VR.
The tested sample suffered a bit from a slight centering defect which shifted the quality
center a little below the geometrical image center.
The Sigma is also compatible to the two Sigma APO EX DG tele-converters. When combined
with the 1.4x (= 210mm f/4 or a "310mm" equivalent) the quality decreases by about one
"school mark" to very good quality levels across the tested aperture range.
Please note that the MTFs charts below represent the performance near infinity
focus. For the time being dedicated macro performance tests are not possible.
Chromatic aberrations (color shadows at harsh contrast transitions) are very well
controlled with an average CA width of less than 0.6px at the image borders.
Surprisingly there´re even less CAs when combining the lens with the Sigma AF 1.4x APO EX DG
tele converter.
