| Sigma AF 17-70mm f/2.8-4.5 DC macro - Review / Test Report - Analysis |
	| Lens Reviews											 -
						Canon EOS (APS-C) |
| Page 2 of 3 DistortionThe distortion characteristic of the lens is about average (in the true sense) for a
zoom lens in this class. At 17mm there is quite pronounced barrel distortion
changing to relatively moderate pincushion distortion at 70mm. The neutral
setting is somewhere between 24mm and 40mm.
17mm:
24mm:
50mm:
85mm:
Expect more distortion towards closer focus distances.
 VignettingTypical for lenses with a reduced image circle vignetting is  pronounced
compared to classic full frame lenses. As to be expected the problem is
most significant at 17mm @ f/2.8 where the vignetting exceeds 1.1EV - this
will be visible in many scenes. However, at all other focal lengths and
aperture settings the issue is actually pretty well under control. If needed
stopping down by 1-1.5 f-stops helps to reduce the vignetting down to a marginal
degree.
 MTF (resolution)In the lab the lens produced pretty impressive resolution figures but it's
not a lens without flaws.
At 17mm the center performance is very good at f/2.8 and excellent
beyond. The borders follow a little behind with good to very good
figures. Unfortunately this isn't true for the extreme corners (roughly 85% off
the center) which are soft at f/2.8. Stopping down helps to lift the performance
here as well but you should use at least f/4, better f/5.6 for a decent quality
level. At f/8 even the extreme corners are very good though.
At 24mm the extreme border problem eases quite a bit and the setting is already
quite usable at wide-open aperture. At f/5.6 the quality is absolutely
exceptional. At 40mm and 70mm the resolution figures are pretty flawless.
Chromatic aberrations (color shadows at harsh contrast transitions) are slightly
better than average for a zoom lens in this class. CAs are somewhat pronounced at
17mm peaking in an average width of 1.3 pixels at the image borders. The problem
eases significantly when moving towards the long end of the zoom range.
