Leica D Vario-Elmar 14-50mm f/3.8-5.6 Asph. OIS - Review / Test Report - Analysis
The Vario-Elmar has a quite moderate distortion characteristic - at 14mm it produces a medium degree of barrel distortion (1.9%) which eases towards the longer focal lengths. There is virtually no distortion from 35mm onwards. That's pretty good for a standard zoom lens actually.
14mm 18mm 35mm 50mm
Vignetting is a problem at 14mm @ f/3.8 - a loss of 1.15EV is nothing to rave about here. At f/5.6 there's still a bit of vignetting left at 14mm and 50mm but at around 0.6EV you don't need to worry about it anymore except in very critical situations. At other settings vignetting is no longer field relevant.
This is the very first lens test performed on the Panasonic L10 so the jury is still out regarding its resolution capabilities. However, it is probably quite safe to state that the Vario-Elmar is a very decent performer with a very high performance throughout the entire zoom range. You may notice the very even center to corner performance straight from the max. aperture and the marginal quality decrease towards 50mm.
However, we'll need to have a look at a fix-focal like the Olympus 50mm f/2 to put all this into perspective.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are quite pronounced at wide end of the zoom range. Regarding an average width around 1.5px at the image borders the problem can be visible in some scenes (including reduced sharpness perception). The problem eases towards longer focal lengths and it's well controlled starting somewhere in the middle range.
