Zeiss Sonnar T* 135mm f/1.8 ZA ( Sony SAL-135F18Z) - Review / Test Report - Analysis
Typical for fix-focal length lenses in this range there're virtually no significant distortion to worry about (~0.15%).
The 135mm f/1.8 is a full format lens and as such enjoying the usual sweet spot advantage when used on an APS-C DSLR. Within this scope the lens shows a little vignetting at f/1.8 (~0.55EV) but this isn't really something to worry about in field conditions. The problem is absolutely negligible by f/2.8.
The Zeiss 135mm f/1.8 ZA produced outstanding resolution figures in the MTF lab. The quality is already exceptionally high at f/1.8 both in terms of contrast and level of detail. The center to border resolution is very even across the aperture range. Stopping down lifts the resolution level a little till peaking around f/4. This is about as good as it gets.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are exceptionally well controlled at large aperture settings with an average CA-pixel width (border) between 0.2px @ f/1.8 and 0.5px @ f/8. Generally this is nothing to worry about in field conditions.
The lens is very resistant against purple fringing - even at f/1.8 - see also some of the sample images which were obtained in rather critical situations.
The quality of the bokeh is naturally of major interest for an ultra-large aperture lens and the Zeiss shows outstanding qualities here again. Out-of-focus highlights show a circular shape from f/1.8 up to about f/2.8. At f/4 the shape deteriorates a marginally. There's no outlining effect. The blur is exceptionally smooth and uniform. However, you may also notice the some longitudinal chromatic aberrations in the cards - more on this in the next chapter.
LoCAs (non-coinciding focal planes of the various colors), sometimes called "bokeh CAs", can be a visible in certain situations. This is slightly surprising regarding the 2 large ED elements in the lens design but it's obviously not enough for a true apochromatic correction (=fully color corrected). The problem isn't as pronounced in field conditions as in the 85mm f/1.4 league (across the different brands) though.
f/1.8 f/2.8 f/4
