Sony 16-105mm f/3.5-5.6 DT ( SAL-16105 ) - Review / Test Report - Analysis |
As mentioned above we're talking about a 6.5x zoom lens here and in this class this translates to a fairly high amount of distortion. Typical for such lenses there's a fairly hefty amount of barrel distortion at 16mm (~3.3%) changing to moderate pincushion distortion at middle to longer focal lengths. The neutral point with basically negligible distortion is around 24mm.
16mm |
24mm |
50mm |
105mm |
Typical for many APS-C standard zoom lenses vignetting can be a rather critical issue at the wide end of the zoom range - ~1.7EV at 16mm @ f/3.5 is fairly massive and disturbing. Stopping down to f/5.6 resolves the most of the problem here and at 24mm. The vignetting is reasonably well controlled at 50mm and 105mm.
The Sony lens produced a rather mixed bag of performance figures in the MTF lab. The center quality is very high at all focal length and it's even exceptional towards the wide end. However, the glory stops when looking at the borders. At large aperture settings the borders are generally soft and at 50mm they're downright poor. The quality increases rapidly when stopping down but it takes f/8 till the lens reaches its best performance (f/11 @ 50mm). The high zoom ratio does obviously take its toll here.
quite low in the middle part of the zoom range but extreme (up to 2px) at 16mm and 105mm. This is far from being impressive although the problem is correctable to some degree if you bother with image post-processing e.g. via Adobe Lightroom.
