Canon EF 24mm f/1.4 USM L - Review / Test Report - Analysis |
Canon EOS (APS-C)
The lens shows slight but still visible barrel distortion.
On an APS-C DSLR the EF 24mm f/1.4 USM L enjoys a sweet spot effect here. However,
this doesn't seem to be enough to produce low vignetting at max. aperture.
Admittedly f/1.4 is a rather extreme setting specifically for a wide-angle lens
but the vignetting shouldn't really exceed 1EV on an APS-C camera. At f/2 the
problem is already reduced to a very acceptable degree and from f/2.8 the
issue is negligible.
The EF 24mm f/1.4 USM L showed two different souls in the lab. The center performance
of the lens already good to very good at f/1.4 increasing to superb
resolution figures from f/2.8 onwards where it easily reaches and
probably exceeds the resolution limits of an 8mp sensor.
Unfortunately the borders aren't quite as good. At f/1.4 they
are soft and it requires f/4 to reach very good territory which is relatively
"late". The border quality peaks at f/8.
The resolution characteristic at the borders is slightly disappointing for a fix-focal lens with this price tag.
CAs (visible as color shadows at harsh contrast transitions) can reach an average CA pixel width
of around 1 pixels at the image borders - an acceptable performance for a wide angle lens but again
a little disappointing for this specific lens.
