Canon EF 24-70mm f/2.8 USM L - Review / Test Report - Analysis
The level of distortion is very low for a standard zoom lens with very slight barrel distortion at 24mm and marginal pincushion distortion at 70mm. At 40mm there is no distortion at all. Really a great performance here for a zoom!
24mm:
40mm:
70mm:
On APS-C DSLRs vignetting is very well controlled with the lens. Wide-open vignetting does not exceed ~0.5EV which is usually not much of an issue in real life situations. One stop down the problem is basically negligible.
Well, I guess everybody has a nemesis and mine is the Canon EF 24-70mm f/2.8 USM L. It took me 4 (f-o-u-r) samples of the lens to get a good one - please note: "good", not a "great" sample. The first three variants showed rather hefty centering defects which spoiled the results quite a bit.
This final sample exhibited a very good to excellent center resolution at wide-open aperture throughout the tested focal length range. The borders follow on a good to very good level. Stopping down lifts the center further into excellent territories and the borders improve gradually till about f/5.6 to f/8. The sweet spot of the lens is in the middle of the zoom range.
Chromatic Aberrations
Lateral chromatic aberrations (CAs) can be visible at 24mm where the average width exceeds 1 pixel at the image border. At the other focal length CAs are practically negligible. All-in-all a very good characteristic for a standard zoom here.
