Canon EF 28-105mm f/3.5-4.5 USM - Review / Test Report - Analysis |
Canon EOS (APS-C)
The lens shows slight barrel distortion at 28mm changing to slight pincushion distortion at the long end.
At around 40mm the level of distortion is negligible.
28mm:
50mm:
105mm:
Expect more distortions towards closer focus distances.
Typical for full format lenses on APS-C DSLRs vignetting is no big issue thanks to taking advantage
of the sweet spot of the lens. It is unlikely that vignetting can be a problem even at wide-open
aperture but in super critical situations you may consider to stop down a little in order to eliminate the
remaining artifacts here.
The EF 28-105mm f/3.5-4.5 USM is fairly unexciting regarding resolution. The center performance is
decent throughout the range whereas the corners perform a little worse as usual - stopping down by
1 f-stop may be a good idea here. There're neither severe show-stoppers here nor is there something to rave about.
However, it is worth to mention that the tested sample had a slight decentering flaw visible at various settings -
nothing extreme but still clearly visible. Compared to fix-focals or L zooms the contrast performance
is also fairly low so you may miss an extra color kick at times.
Chromatic aberrations (color shadows at harsh contrast transitions) are a relatively minor
problem with this lens with an average pixel width of less than 1 pixel except at 28mm beyond f/8
(see also the left roof in the last sample shot below).
