The level of distortion is reasonably well controlled for a zoom lens.
At 50mm there is relatively pronounced barrel distortion (1.1%) changing to moderate pincushion
distortion (0.9%) at 135mm. At 85mm the two forces even out.
50mm:
85mm:
135mm:
The Tokina is a dedicated APS-C lens so vignetting is a little bit more pronounced here
specifically at f/2.8. At 50mm and 85mm the issue is still moderate with a max. vignetting around 0.6EV
whereas the vignetting increases to 0.83EV at 135mm. Nonetheless this is still fairly decent for
such a kind of lens.
The Tokina AF 50-135mm f/2.8 AT-X Pro DX exhibited a very good to exceptional performance
in the MTF lab. At 50mm the resolution is extremely high throughout all tested
aperture settings. At f/4 and f/5.6 the values are even among the highest tested to date on the EOS 350D.
There is a performance penalty at 85mm f/2.8 which affects the image borders (only) but
from f/4 onwards the resolution is superb again. At 135mm there is a slight drop in
performance which also affects the center resolution at f/2.8. The contrast level is also somewhat
affected here. Beyond wide-open aperture the quality is excellent. All-in-all quite impressive.
The lens suffered somewhat from a rather pronounced field curvature which may result in
softer corners when shooting flat objects with a shallow depth-of-field.
The Tokina exhibits relatively pronounced lateral CAs (color shadows at
harsh light transitions) peaking around 0.9px at 50mm and 1.4px at 135mm f/2.8.
Expect that CAs can be easily visible at 135mm especially at the extreme borders
and large aperture settings.
