Tamron AF 90mm f/2.8 SP Di macro - Review / Test Report - Sample Images & Verdict
Ok, finally here're some sample shots taken with the EOS 350D - all RAWs converted via Raw Shooter Premium v1.0.
Click on a thumbnail to view the original file (opens in a separate window). Please note that the full-size images are supplied in JPEG2000 format. You should be able to display the images in most modern imaging applications such as Photoshop. This is a measurement to limit the bandwidth which is a scarce resource.
Make
Model Canon EOS 350D DIGITAL
Focal Length 90.0mm
Exposure Data: f/8.0 @ 1/200s
Size 2312x3472
Make
400
90.0mm
f/2.8 @ 1/2000s
2312x3472
Make
ISO Speed 400
Focal Length 90.0mm
Exposure Data: f/3.2 @ 1/1600s
Size 2312x3472
Make
400
90.0mm
f/16.0 @ 1/8s
3472x2312
The Tamron AF 90mm f/2.8 SP Di is a superb lens without any significant flaw. In fact optically it is every bit as good, maybe even slightly better than the Canon EF 100mm f/2.8 USM macro. The lens has a very good build quality. Nonetheless it's not quite as impressive as the Canon in this respect because it extends during focusing and regarding AF noise. That said the price tag is also somewhat lower so the verdict can only be - HIGHLY recommended!
