Canon EF-M 22mm f/2 STM - Review / Lens Test - Sample Images & Verdict
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/4.0
Exposure 1/500s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/7.1
Exposure 1/500s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/7.1
Exposure 1/200s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/7.1
Exposure 1/250s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/2.0
Exposure 1/4000s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/7.1
Exposure 1/320s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/4.0
Exposure 1/1000s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/2.5
Exposure 1/2500s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/7.1
Exposure 1/200s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/7.1
Exposure 1/320s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/2.0
Exposure 1/2000s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/2.0
Exposure 1/4000s
Make Canon
Model Canon EOS M3
ISO Speed 100
Focal Length 22.0mm
Aperture: f/7.1
Exposure 1/640s
Canon did a good job once more. The Canon EF-M 22mm f/2 STM may be a tiny lens but it is an impressive performer nonetheless. The center quality is great throughout the relevant aperture range and the borders are also very impressive. There's some softness in the image corners at large apertures though and this is somewhat emphasized by a bit of field curvature. Stopping down lifts the corner performance significantly. It is worth to note that the close focus performance seems to be a bit worse though (just from visual observation). Image distortions are negligible and lateral CAs are well controlled. In critical scenes you may spot some purple fringing at f/2 but that's rather normal for a such a large aperture lens. On the downside the vignetting is on the high side even when stopped down. The bokeh is Okay for a moderate wide-angle lens but you will notice some smearing effects in difficult scenes.
The Canon EF-M 22mm f/2 STM is a simple being in mechanical terms. However, the implementation is really good thanks to decent quality materials and a tight assembly. The lack of "substance" (weight) may give you the impression of handling a toy but objectively there's no reason for complaints here. Typical for all EF-M lenses, the auto-focus is driven by Canon's noiseless STM (Stepping Motor) which operates reasonably fast but it's not class leading.
Coming to a conclusion we'd say that This very affordable lens is pretty much a no-brainer especially if you're after a super-compact setup.
Mechanical Quality: to
