Canon EOS 500D (Rebel T1i) - Review / Test Report - Sensor Noise |
DSLR Reviews -
DSLRs
Page 4 of 7
ISO noise
Let's have a look at the results of Canons' 22.3x14.9mm C-MOS sensor with respect to the ISO performance. Let's start with the RAW-converted images:
The EOS 500D is generally a good performer throughout the ISO range. There are no problems at ISO 100/200
and ISO 400 and ISO 800 are also perfectly fine for most scenes. However, at ISO 1600 and ISO 3200 the noise
level is starting to have a higher impact but it's still usable in some situations.
Now what about the JPEG results...
If you move your mouse cursor over the image you can switch the corresponding JPEG results, Noise reduction ON and OFF
The JPEG output shows basically a full stop noise advantage at ISO high settings compared to the converted RAW files,
but the increasing noise reduction towards high ISO settings comes at cost of resolution and dynamic range - specifically
at high ISO settings.
These are the lab results but I guess you're also interested in some samples taken in the real world. The first image series
should give you an idea of the color noise at the specific settings.
If you move your mouse cursor over the image you can switch the the corresponding JPEG results
Verdict:
 | high ISO noise (ISO 1600-3200):
