Page 7 of 9
Nature Photography
The EOS 7D is perfectly suitable for nature photography. The image quality is very good all the way
up to ISO 800 which probably as high as it needs to be for this purpose.
The "Integrated-Cleaning-System" seems to work fine - we weren't able to spot any sensor dust during
out tests. The body sealing against dust and moisture comes handy in some of the tougher outdoor
situations. Please note that you will need corresponding lenses in this case. The offered kit
lenses are not sealed to the same standards. The battery life is fairly good at around 400 images
of mixed usage.
In terms of lenses there're lots of interesting options like the Canon EF-S 10-22mm f/3.5-4.5 USM,
EF-S 17-55mm f/2.8 USM IS or the EF 70-200mm f/4 USM L IS. If you're into wildlife or birding
there're lots of super-tele lenses to choose from ... at a price. The biggest problem of the 7D
is not the lack of lenses but the lack of lenses that can exploit its (megapixel-)potential.
If you're into full HD video the EOS 7D will fit your needs as well. The APS-C sized sensor
does make a difference compared to the dwarfish sensors used in most conventional HD camcorders
out there.
Macro Photography
Macro photography means Live-View these days and, just like all the competitors, the EOS 7D
offers this feature albeit based on a fixed screen rather than on an articulated one which is
a bit unfortunate. Activating Live-View is as easy as pressing the corresponding button (which
can be configured to activate either HD video or Live-View). Objects can be enlarged up to
10 times for accurate manual focusing.
There're currently no less than 6 dedicated macro lenses
made by Canon plus numerous more from the thrid-party gang so you should be able to find
something here. Canon has two dedicated flash units for macro photography - the Macro Twin Lite MT-24EX
and the Macro Ring Lite MR-14EX. If this is not enough these units can be coupled with additional
slave flash inits.
Night/Low-Light Photography
The EOS 7D is reasonably suitable for night/low-light photography. Its high ISO performance is rather
typical for an APS-C DSLR and as such not overly impressive beyond ISO 800, maybe ISO 1600.
The long exposure noise reduction works fine so tripod-based night images are no problem. As usual bulb
exposure is available but it's not programmable so the the exposure button has to remain pressed during
the whole exposure.
The viewfinder of the 7D is big and bright so it's comparatively easy to compose your scene in
dark conditions. Alternatively Live-View may also used of course.
Canon offers lots of IS lenses which help to shoot are comparably low ISO settings (at cost of shutter speed)
in some situations. The lens portfolio does also include an industry leading range of
ultra-large aperture lenses which can be useful here. The Speedlites 430EX II and 580EX II
may also be suitable at times in order to keep lower ISO settings.
Portrait Photography
The min. X-sync of 1/250sec is generally fine for the typical focal lengths used for portrait photography
(~50-135mm) and high-speed sync. is also available with external flashunits. Furthermore, the camera
supports remote flash capabilities for balanced lighting using multiple flash units without the need
to purchase a corresponding remote transmitter units.
The Canon lens lineup has a number of highly interesting lenses for portrait photography - namely
the EF 50mm f/1.2L, EF 85mm f/1.2L or one of the popular 70-200mm f/2.8s. The Speedlites 430EX II
and 580EX II are worth a thought - both can be used in bounce mode (tilt + swivel) and they're
powerful enough to be used with diffusors for producing soft light conditions.
Sports Photography
The EOS 7D can shoot continuously with up to 8 frames per second in image bursts of 126 JPEGs or
15 RAWs. The phase detection AF is extremely fast and accurate even in low light conditions.
Unlike lower spec EOS DSLRs the 7D supports AF sensor handover so it can follow a tracked object
across the frame (within the AF array zone).
The Canon lens lineup offers numerous long tele lenses so whatever you're looking for you should
be able to find it here. There's a reason why most sports photographers prefer Canon here. The
Speedlite 580EX II (GN 58 @ 105mm) should be strong enough for freezing some moderately fast
indoor actions.
