Fujinon XF 16mm f/1.4 R WR (Fujifilm) - Review / Test - Analysis
Lens Reviews - Fujifilm X
The distortion level of the Fujinon is marginal at just ~0.7% (barrel-style). The lens is fully corrected thus auto-correction is not necessary here.
In terms of vignetting there are two sides of the story. Fujifilm uses auto-correction to control the light falloff. This works quite well with a comparatively moderate, albeit visible peak of 0.9EV (f-stops) at f/1.4. Stopping down to f/2 reduces the issue and it's not relevant anymore from f/2.8.
The original characteristic of the lens is worse than that though. Without auto-correction the vignetting reaches a heavy 2.2EV (f-stops) at f/1.4. Unsurprisingly the situation improves at f/2 and mostly resolved from f/2.8.
High-speed lenses -especially wide-angles, tend to have a complex MTF characteristic. The Fujinon XF 16mm f/1.4 R WR delivers an above average performance (in the true sense) here. At f/1.4 the center sharpness is very good although it doesn't bite here yet. The borders are good whereas the extreme corners are soft. Stopping down to f/2 boost the center to excellent levels and recovers the corners which are now decent (other than for some field curvature). The peak quality is reached at f/4 with an excellent center and a very good outer image field. Diffraction starts to kick in at f/8 with a higher impact from f/11. The quality at f/11 remains usable but you shouldn't go beyond.
The centering quality of tested sample was Okayish - in the real world images showed some softness on the right image side. The field curvature is fairly high at f/1.4 and f/2 but dissolves beyond.
The lateral CAs (color shadows at hard contrast transitions) are very low with an average pixel width of 0.2-0.3px at the image borders. This is negligible. In extreme scenes you may spot some purple fringing though.
A key feature such a large aperture lens is the rendition of out-of-focus areas aka the "bokeh". Due to the wide-angle nature of the Fujinon we weren't able to perform the full set of tests here but we were quite pleased - even more so because wide-angle lenses aren't overly renowned for a nice out-of-focus rendition.
Out-of-focus highlights are nicely rendered at f/1.4 with some minor imperfections in the inner disc zone and slight outlining which increases towards the borders. Stopping down to f/2 reduces the outlining effect. An edgy aperture shape emerges at f/2.8 and more so at f/4.
The border highlights remain roughly intact (see below) whereas some rough "cat's eyes" are showing up in the extreme corners. This issue is comparatively underdeveloped for an ultra-wide angle lens though.
Expect some bokeh fringing at large aperture but this is normal at such speeds - see the greenish halos below for instance.
