Nikkor AF 28mm f/2.8D - Review / Test Report - Analysis
The AF 28mm f/2.8D exhibits relatively pronounced barrel distortion (1.2%) which is a little more than desirable for a fix-focal lens.
The AF 28mm f/2.8D is a full frame lens thus enjoying a sweet spot advantage on APS-C DSLRs. Nonetheless it still produces very pronounced vignetting of one full stop at wide-open aperture (f/2.8) - a little disappointing. However, from f/4 and up the issue is not field-relevant anymore.
The Nikkor produced very decent resolution figures in the MTF lab. The center performance is already very high at wide-open aperture and it even reaches the resolution limits of the D200 by f/5.6. The border quality is very good but doesn't really improve when stopping down (as opposed to the depth-of-field naturally).
Similar to the Nikkor AF 24mm f/2.8 D the lens suffers from residual spherical aberrations (focus shifts when stopping down) - a fate shared by a couple of lenses of that design era. The lens also exhibits a quite high degree of field curvature.
Chromatic aberrations (color shadows at harsh contrast transitions) are relatively low at wide-open aperture but they increase when stopping down. At f/8 CAs peak at around 1.6 pixels on the average at the image borders - this is too high for a fix-focal lens. Please note that the issue can be corrected via several imaging applications or tools.
The principal design of the Nikkor AF 28mm f/2.8D is obviously closely related to the AF 24mm f/2.8D so it shares some of its characteristics. The resolution figures are very good but otherwise the lens left something to be desired for a fix-focal. The lens exhibits relatively high barrel distortions, very high vignetting at f/2.8 and pronounced CAs. Spherical aberrations (focus shifts when stopping down) and high field curvature on top don't make things any better. Compared to modern lenses the Nikkor seems to be a little dated but naturally it still remains a very good lens with a few bugs.
