Nikkor AF 35mm f/2 D - Review / Test Report - Analysis
The AF 35mm f/2D exhibits a moderate degree (0.64%) of barrel distortions which shouldn't show up in most real world images.
The AF 35mm f/2D is a full frame lens thus enjoying a sweet spot advantage on APS-C DSLRs. Nonetheless it still produces a relatively pronounced max. vignetting of 0.74 EV at wide-open aperture which is a little higher than desirable for such a lens. However, from f/2.8 the issue is basically negligible.
The Nikkor showed quite impressive resolution figures in the MTF lab. The center performance is excellent straight from the max. aperture setting whereas the borders are only able to reach an average level here. However, at f/2.8 the borders improve significantly to very good quality. The peak performance of the lens is reached in the f/5.6 to f/8 range where both the center as well as the borders are excellent.
Chromatic aberrations (color shadows at harsh contrast transitions) are relatively moderate with a maximum well below 1 pixel on the average at the image borders. At f/4 there's a local minimum of just 0.3 pixels which is very low. Generally the issue shouldn't produce any headaches in most scenes.
