Nikkor Ai-S 50mm f/1.8 - Review / Lab Test Report - Analysis |
As expected for a fix-focal lens the level of (barrel) distortion is very low (0.21%)
and nothing to worry about.
Thanks to the sweet spot behavior on the D200 vignetting is very well controlled.
Wide-open vignetting is a little stronger at ~0.61EV which may be visible in
very critical scenes. From f/2.8 and up the problem is negligible.
Standard lenses are stellar performer when used at medium aperture settings
and the Nikkor Ai-S 50mm f/1.8 is no exception here. At f/4-f/8 the lens
is as good as it gets on the D200 with an excellent center
and a very-good to excellent border performance. Nonetheless it is also
fairly typical for ultra-large aperture lenses that things aren't quite as rosy at
wide-open aperture but the center is already excellent here whereas the borders
are a bit soft (combined with rather low contrast).
It is interesting to note that the MTF curve is basically identical to the one of the AF 50mm f/1.8D.
Chromatic aberrations (color shadows at harsh contrast transitions) are well controlled
and slightly lower than in the tested AF variant.
The Nikkor Ai-S 50mm f/1.8 performed basically identical to the current AF D model
so it's your choice whether you prefer AF and a plastic construction or smooth manual
focusing in a solid package. At wide-open aperture it is a
little soft at the image borders and the contrast level is a little on the low
side. However, at medium aperture settings the resolution figures are exceptionally
high. Distortions are negligible and vignetting as well as CAs are very well controlled.
