Nikkor AF-S 18-55mm f/3.5-5.6 G ED DX II - Review / Test Report - Analysis
The AF-S 18-55mm II shows the quite typical distortion characteristic for a lens in this class. At 18mm there is very pronounced barrel distortion which eases continuously towards the long end of the zoom range. At 55mm the lens is basically free of distortion.
18mm 24mm 35mm 55mm
As mentioned the AF-S 18-55mm DX II is a reduced image circle lens (APS-C) and typical for such lenses the vignetting is more pronounced compared to classic full frame lenses. As to be expected the problem is most significant at 18mm @ f/3.5 where the vignetting exceeds 1.1EV at the image borders. However, this is only a local issue and a much lesser problem at other focal lengths. At 18mm it can easily be resolved by stopping down a little. Nonetheless the issue is pretty well under control for a DX-type lens.
The Nikkor AF-S 18-55mm DX II produced surprisingly high resolution figures under lab conditions which is quite unusual for a lens in this price class. The center resolution is excellent throughout the zoom range. The border quality at the wide-end of the zoom range is soft results at max. aperture - both regarding resolution and more so contrast. However, stopping down to f/5.6 already improves the borders significantly. At 35mm and 55mm the resolution characteristic is more even across the frame.
You may find the resolution of this lens to be quite astonishing and maybe hard to believe. As a reference here´s comparison of 100% portions of the test chart (center bottom) between this lens and the (very high quality) Nikkor AF 50mm f/1.4D at f/5.6:
  • Nikkor AF-S 18-55mm f/3.5-5.6G ED DX II @ 18mm f/5.6
  • Nikkor AF 50mm f/1.4 @ 50mm f/5.6
    You may also notice that the center performance is one step up from the test of the original (mk I) variant. This does surely originate in a better centering of the mk II sample though centering has a rather different meaning regarding the degree of wobbling of the inner lens tube.
    Chromatic aberrations (color shadows at harsh contrast transitions) can be a problem at and below 35mm. The average CA pixel width at the image borders easily exceeds 1px with a peak at 18mm f/3.5 (1.7px). This will be visible in some situations unless you correct the issue via an imaging application.
    Regarding the identical optical design you may check out the sample images of the predecessor.
    The Nikkor AF-S 18-55mm f/3.5-5.6 G ED DX II is a marginal update to the original mk I variant. The optical design has not been changed so the general observations regarding image quality remain the same. The tested mk II sample has a sightly better centering thus resulting in an improved center quality but regarding the mechanical qualities of the lens this is a gamble rather than a new feature of the mk II series. The resolution figures are actually very good and no worse than those of much higher priced models - truly remarkable. The contrast level at large apertures (primarily wide-end) leaves something to be desired though. The distortion characteristic is about average whereas vignetting is surprisingly well controlled for a DX-type lens (APS-C image circle). Chromatic aberrations are quite high and can be field relevant in some situations. Naturally this has all to be seen in the context of the extremely low price tag so all-in-all it is almost surprising what the lens is capable to deliver. If you use ~f/6.7-f/11 you'll be a happy camper in most situations. Nonetheless there's no such thing as a free lunch and price level of the Nikkor AF-S 18-55mm f/3.5-5.6 G ED DX II shows up in the build quality which is clearly sub-standard. This is probably a sufficient reason alone for some to think about the AF-S 18-70mm f/3.5-4.5G DX or AF-S 18-135mm f/3.5-5.6G DX as alternative investments.
  • Disclosure: When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network and Google Adsense.
