Nikkor AF-S 70-200mm f/2.8 G IF-ED VR - Review / Test Report - Analysis
The AF-S 70-200mm VR has a very moderate 3x zoom ratio and the level of distortion is quite low accordingly. At 70mm there's a moderate degree of barrel distortion (0.7%) changing to moderate pincushion distortion (0.7%) at the long end of the zoom range.
70mm 135mm 200mm
On an APS-C DSLR the full-frame AF-S 70-200mm VR can take advantage of a sweet spot effect. At 70mm and 135mm the issue is negligible even at f/2.8. At 200mm at f/2.8 vignetting is a little more pronounced but still not overly field relevant. If needed stopping down a little will solve the problem completely.
In the MTF lab the first sample lens delivered good to very good resolution figures but suffered from a rather pronounced centering defect - this is actually not overly unusual for Nikon VR lenses if the local testing history serves as a guidance. In the meanwhile a 2nd sample has been tested that performed significantly better - these results are presented below.
Generally the both the center and border resolution is excellent throughout the tested focal-length and aperture range. At 70mm the results are stellar and about as good as it gets on the Nikon D200. At 135mm and 200mm there´s a marginal decrease in quality which shouldn´t be really field relevant. The sweet spot of the lens is located around f/5.6.
Chromatic aberrations (color shadows at harsh contrast transitions) are generally well controlled with a local peak of 1.2px on the average at the image borders at 70mm f/2.8.
