The Zeiss T* 85mm f/1.4 ZF produces an absolutely negligible degree of distortion (<0.01%).
The Zeiss lens exhibited the typical vignetting characteristic for full frame, ultra-large
aperture tele lenses used on an APS-C DSLR. At wide-open aperture the vignetting is
moderate with 0.6EV. Starting at f/2 the problem is negligible under field conditions.
Similar to most of the other Zeiss ZF lenses the Planar T* 85mm f/1.4 produced outstanding
resolution figures in the lab.
The center resolution is already excellent at max. aperture whereas the borders
are a bit softer but already very good. The contrast is a somewhat "dreamy" at this
setting. Between f/2 and f/5.6 the center quality
is nothing short of superb. The border quality increases steadily till reaching
its (outstanding) peak at f/5.6. At f/8 and beyond diffraction is the limiting
factor (as usual).
Based on some field the quality seems to decrease significantly at very close
focus distances.
Chromatic aberrations (color shadows at harsh contrast transitions) are
very moderate varying between an average pixel width of 0.7px and 0.4px
at the image borders. Similar to the Nikkor AF 85mm f/1.4D the Zeiss
suffers somewhat from purple fringing at large apertures.
Typical for many ultra-large aperture lenses the Zeiss also shows some
Longitudinal Chromatic Aberrations (LoCA) resulting in greenish and reddish
out-of-focus edge transitions. See also some of the provided sample shots.
