Voigtlander Ultron 40mm f/2 SL II (Nikon mount) - Review / Test Report - Analysis |
The Ultron produces some mild barrel distortion (0.6%) which is usually nothing
to worry about in field conditions.
The 40mm f/2 is a full format lens thus enjoying a sweet spot advantage
on APS-C DSLRs. However, there's still a bit of vignetting visible at
f/2 (0.63EV) but it doesn't reach really disturbing levels. The problem is
negligible from f/2.8 onwards.
The resolution figures produced by the Voigtlander are pretty impressive throughout
the tested aperture range. At f/2 the resolution is already very high both in the
center as well as the borders. At f/4 the center quality receives a boost into
extreme resolution territories - it surely exceeds the sensor resolution here
as well as at f/5.6. The border quality increases steadily from f/2 towards medium
aperture settings although it generally remains within very good(+) quality scope here.
Chromatic aberrations (color shadows at harsh contrast transitions) are
slightly higher than average for a fix-focal length lens in this class.
The CAs aren't extreme but at around ~0.8px on the average at the image
borders they aren't totally negligible either.
Voigtlander lenses have quite a reputation when it comes to the
quality of the bokeh - the rendering of the out-of-focus zones. Unfortunately
the Ultron is a bit of a exception to the rule here. Out-of-focus highlights
are pretty circular but at f/2 they have a bright, outlined perimeter. Fine structured,
high contrast objects can appear rather "nervous" here - see e.g. the first card in
the foreground of the bokeh stress test scene below. You may also check out
some of the scenes shot at f/2 in the sample image section. The silver balls in
the foreground show a bit of purple fringing but this is a comparatively mild
effect for an f/2 lens. Stopping down improves the bokeh quite a bit (marginal
outlining, smoother transitions) but regarding the focal length most users have
probably a priority on the max. aperture setting.
You can download the full-size sample images here:
f/2 and f/4
