Tamron 500mm f/8 SP macro (Adaptall-to-Nikon) Review / Test Report - Sample Images & Verdict
Ok, finally here're some quick'n dirty sample shots taken with the Nikon D200 (converted RAWs via RawShooter Premium 2006). These images were taken from a monopod which was probably not sturdy enough to get the maximum potential the lens can give you.
Make NIKON CORPORATION
Model NIKON D200
ISO Speed 400
Focal Length 180.0mm
Exposure Data: f/8.0 @ 1/1500s
Size 3898x2613
Model NIKON D200
ISO Speed 400
Exposure Data: f/8.0 @ 1/640s
Size 3264x2328
Model NIKON D200
ISO Speed 640
Exposure Data: f/8.0 @ 1/1000s
Size 3898x2613
Model NIKON D200
Exposure Data: f/8.0 @ 1/500s
Size 3898x2613
When used with care the Tamron 500mm f/8 SP mirror lens can be able to produce decent results but don't expect this to be easy - most of my real life sample images were blurred (caused by shake). A (max.) aperture of f/8 is very slow for a 500mm lens (750mm equivalent on APS-C) to start with and effectively this is a f/11 (or to be precise: T/11) lens due to the light loss caused by the secondary mirror. For reasonably sharp results you either need a very sturdy tripod or extremely fast shutter speeds (1/750sec or faster). When used "hand-held" you will need to choose very high ISO settings even in bright light conditions which can't be desirable in terms of image quality and a tripod would destroy the weight advantage of a mirror lens in field conditions. The rather poor bokeh may be a funny effect in the beginning but once the initial coolness is gone it is just odd and often disturbing. Unless you want to have a lens for "emergency" use you should probably better consider conventional tele lenses.
