Sigma AF 50-150mm f/2.8 EX DC HSM (Nikon mount) - Review / Test Report - Analysis |
The Sigma produces slight barrel distortion at 50mm (~0.8%) changing to slight pincushion distortion
at 100mm (~0.9%) and moderate pincushion distortion (~1.4%) at 135mm.
| 50mm |
100mm |
150mm |
As mentioned in the introduction the Sigma is a dedicated APS-C lens with correspondingly
smaller glass elements. This results in a comparatively higher degree of vignetting - less
so at 50mm and 100mm but at 150mm the problem is fairly pronounced (1EV @ f/2.8). In
critical situations you should stop down to f/4 here.
The Sigma was able to produce very impressive resolution figures in the MTF lab.
This is especially true for the 50mm and 100mm setting where the center to border
characteristic is generally excellent from f/2.8 down to f/8 (apart from a few
very good+ border and extreme corner portions). At 150mm there's a drop in quality
specifically at f/2.8 - the center and border is still very good but
the extreme border quality drops down to only fair quality here. However, the corners
do pretty much catch up by f/4. The peak performance is reached between f/5.6-f/8
with an excellent center and very good borders/corners.
It is worth to mention that this doesn't seem to be the complete story. At 150mm I wasn't really
able to get any good field images from this lens at very close focus distances (<1.5m).
The contrast level is very poor here (SAMPLE).
To be fair this is normal up to some degree for all non-macro lenses but in my opinion
Sigma should have chosen a more conservative minimum focus distance.
Lateral Chromatic aberrations (color shadows at harsh contrast transitions) are
very well controlled for a zoom lens. At 50mm and 100mm it's pretty much a non-issue.
This is also true at 150mm @ f/2.8-4 but beyond CAs are increasing to (still)
moderate levels.
