Sigma AF 70-200mm f/2.8 EX DG HSM APO macro (Nikon) - Review / Test Report - Analysis |
The 70-200mm EX has a very moderate 3x zoom ratio and the level of distortion is quite low
accordingly. At 70mm there's a moderate degree of barrel distortion (0.7%) changing to
moderate pincushion distortion (0.7%) at the long end of the zoom range. This is usually
not field-relevant.
70mm |
135mm |
200mm |
The 70-200mm EX is a full format lens which enjoy a sweet spot advantage when used on
an APS-C DSLR. At 70mm and 135mm the vignetting is negligible even at f/2.8. At 200mm at
f/2.8 it is a little more pronounced but still not overly field relevant.
If needed stopping down a little solves the problem completely.
The Sigma was able to produce very decent resolution figures in the lab.
At 70mm the center resolution is on a very good level followed by good to very
good borders. At f/4 and f/5.6 there's a boost in quality which peaks in
an excellent center to border performance. This characteristic remains roughly
intact at 135mm. At 200mm there's a slight decrease in center performance
whereas the borders are already on a very good level straight from f/2.8.
Chromatic aberrations (color shadows at harsh contrast transitions) are
generally well controlled with a peak of ~1.1px on the average at the
image borders at 135mm and 200mm.
