Micro Nikkor AF-S DX 85mm f/3.5 G ED VR - Review / Test Report - Analysis |
With just short of 0.6% the lens shows a slight amount of barrel type distortion. This is a little more than what one would expected from a fixed focal micro lens, however for most usage scenarios this can still be regarded as distortion-free under field conditions (unless for really demanding shots like reproduction work).
Being a DX lens on the one hand, but with rather moderate speed on the other hand, the Micro Nikkor is not really expected to show heavy vignetting wide open. Nonetheless the lens surprises with very visible vignetting of more than 1 stop in the image corners wide open. Stopping down of course helps to reduce the corner falloff considerably, from f/5.6 onwards it's no longer field relevant.
Please note, that specifically for the vignetting as well as the bokeh section below we also included figures for f/4 to provide a better image of the measured effect.
Macro lenses usually are very sharp and the Micro Nikkor 85 VR is no exception to this rule. The image center shows excellent resolution wide open already until diffraction kicks in at f/16, the image borders and extreme corners follow only slightly behind, starting with very good resolution wide open and reaching excellent sharpness slightly stopped down.
Sharpness decreases towards the lens minimum aperture of f/22 due to diffration, however this is a physical limitation and not a design flaw of the lens.
Please note that the MTFs charts below represent the performance near infinity focus. For the time being macro performance tests are not possible.
Lateral CAs (color shadows at harsh contrast transitions) are very well under control with average values of 0.3 pixels at the image border. This is certainly not field relevant.
Given the rather moderate maximum aperture, the lens is not the primary choice for portraits or similar shots, where subject separation is required. In macro shots however the amount of depth of field is usually very limited, so the quality of the bokeh (the out of focus areas) is of major interest here nonetheless.
Even though the amount of subject separation is limited in our test scenario, the lens produces a very pleasing blur with nice and evenly filled background highlights, which show a bit of a cat's eye shape wide open and develop some outlining when stopped down.
Please note that for this section we also included f/4 shots, an aperture setting that was not measured seperately in the MTF and CA sections above.
Bokeh fringing shows up as magenta colored halos in front the focus point and green beyond. The Micro Nikkor shows a moderate level of bokeh fringing wide open and stopping down helps to reduce the issue considerably.
f/3.5 |
f/5.6 |
f/8.0 |
f/11 |
