Nikkor AF 85mm f/1.8 D (DX) - Review / Lab Test Report - Analysis
On DX cameras the lens is free of distortion.
Being a FX lens, the Nikkor profits from the sweet spot advantage on DX cameras and consequently shows only minor vignetting wide open, which is reduced to an irrelevant level at f/2.8 and beyond.
The image center shows very good resolution wide open already. Stopped down to f/2.8 and beyond, the resolution is excellent at all tested aperture settings.
The borders and corners follow a bit behind with just good sharpness wide open. However, stopped down to f/2.8 the sharpness already reaches very good values here and even excellent resolution at f/5.6 and f/8.
Chromatic aberrations (color shadows at harsh contrast transitions) are very low and exceptionally well controlled.
The image blur in front of the focal plane is very smooth, however that's not something you'll often benefit from in real world shots. Behind the focal plane the bokeh quality is a bit lower, with slightly nervous blur.
Background highlights show some outlining wide open that can be reduced by stopping down. At large apertures the highlights have a circular shape (except towards the image borders, where they are slightly cut off due to mechanical vignetting), but stopped down the shape of the aperture begins to form polygons instead.
Typical for most fast primes the AF-D 85 shows noticeable bokeh fringing at large aperture settings, which can of course be reduced by stopping down.
f/1.8 f/2.8 f/4.0 f/5.6 f/8.0
The Nikkor AF 85mm f/1.8 D performs on a very high level. Sharpness is very good wide open and excellent across the frame stopped down.
Typical for a fast prime there is some visible vignetting as well as bokeh fringing wide open, both of which can be reduced by stopping down. CAs and distortion are very well controlled.
The build quality is on a high level. Not quite up to pro standards, but certainly nothing to worry about for the average shutterbug. If anything, it looks a bit outdated compared to newer AF-S lenses.
So, does it perform better than its faster and more expensive cousins? Well, not quite, there is one property where it falls short: bokeh. The quality of the background blur is not bad, but lower than with most ultra fast portrait primes. If you're after buttery smooth bokeh, this is not your primary choice. For anyone else, though, the lens offers tremendous value for a quite affordable price.
