Nikkor AF-S DX 18-105mm f/3.5-5.6G IF-ED VR - Review / Test Report - Analysis
Typical for zoom lenses of this class the AF-S 18-105 VR shows quite pronounced barrel distortion at its shortest focal length. At 24 mm the distortion already flips over to the pincushion type, allthough at a rather moderate level. At 35 mm the amount of pincushion distortion has increased significantly and stays on a rather high level for the rest of focal range.
18mm 24mm 35mm 50mm 105mm
Lenses with reduced image circles designed for DX cameras usually show pronounced vignetting at max. aperture. The AF-S 18-105 VR is no exception to this rule with the highest amount of vignetting visible at the extreme ends of the zoom range. Wide open at 18mm, 24mm and 105mm vignetting can be disturbing (depending on the subject). Stopping down one stop reduces the issue to a level that's hardly field-relevant.
The lens delivers excellent resolution in the image center for most of its focal range. Only at the long end the sharpness drops to still very good figures throughout the tested aperture range.
The borders and corners lag a bit behind, but generally offer good to very good resolution. However, they never reach excellent sharpness on our scale. As in the image center, the sharpness drops towards the longest focal length.
The level of lateral CAs (color shadows at harsh contrast transitions) is rather high, reaching peak values of almost 1.9px and generally well above 1 px at most focal lengths and aperture settings.
