Nikkor AF-S DX 10-24mm f/3.5-4.5G ED - Review / Test Report - Analysis
10 mm is a rather extreme focal length and some barrel distortion is to be expected here. However, at 3.1% the Nikkor shows a fairly large amount of it, certainly more than the competition. The good news is that at longer focal lengths distortion is very well controlled at around or slightly above 0.5%, switching from barrel to pincushion distortion between 14 and 18 mm.
10mm 14mm 18mm 24mm
Lenses with reduced image circles designed for APS-C digital SLRs usually show slightly pronounced vignetting. This is not really the case here, allthough there's almost a 1 stop penalty wide open, the amont of vignetting is actually moderate for such a wide angle zoom.
At 10mm, the lens delivers excellent center resolution straight from the maximum aperture. The borders follow closely behind with very good resolution across the tested aperture range. The extreme corners are a very different story, though. Wide open, the resolution is poor, but stopped down to f/8 the borders reach very good results, too.
At all other tested focal lengths, the lens delivers very good (wide open) to excellent (stopped down) resolution in the image center. Slightly stopped down to f/5.6, the borders and corners show very good resolution.
Just like vignetting, CAs (color shadows at harsh contrast transitions) reach values of more than 2 pixels at the image borders at the short end of the zoom range. Zoomed in to the longest focal length, CAs are considerably lower. For a wide-angle zoom this is typical behaviour, even though the absolute CA values are a bit on the high side.
