The lens shows barrel distortion at around 1.9%. This can be visible and disturbing for subjects with straight lines near the image border. However, the distortion is uniform and thus easy to remove in post processing.
The Nikkor shows very pronounced light falloff towards the image corners wide open and also at f/4. Stopped down to f/5.6 and beyond vignetting is reduced to a level that is no longer an issue for most subjects.
In the image center the lens shows very good resolution wide open already, reaching excellent sharpness from f/4 onwards (until diffraction limits the maximum achievable resolution at f/11 and beyond).
The borders and corners follow quite a bit behind. Wide open the borders show good reolution, the corners are very soft, though. Stopping down helps to increase reolution, but even at their peaks borders and corners only just reach very good resolution figures.
Chromatic aberrations (color shadows at harsh contrast transitions) are well controlled at large apertures, but increase considerably by stopping down. However, CAs can easily be corrected in software or by the camera itself (if you shoot JPEGs and own a current Nikon DSLR).
A 28mm prime is not primarily designed to throw the background out of focus (to the contrary, actually). However, with its ability to focus rather close combined with the large aperture the lens is able to separate the main subject from the background (at least for larger subject-to-background distances). So, let's have a quick look at the bokeh quality.
Out of focus areas show some nervousness and double contures. Background highlights are somewhat distorted towards the image borders at f/2.8 and f/4 From f/5.6 onwards the aperture shape with its straight blades (not rounded) starts to become visible here. Quite strong outlining increases the overall unpleasant character of the lens' bokeh.
