Zeiss Distagon T* 25mm f/2.8 ZF (FX) - Review / Test Report - Analysis |
Nikon / Nikkor (full format)
The Zeiss Distagon 25mm f/2.8 produces a moderate degree (~1.7%) of barrel distortion. This is about average for a prime lens in this class.
The vignetting characteristic seems to be a real weakness of Zeiss Z-series lenses when used on full format DSLRs. The Distagon shows a fairly extreme deterioration of ~1.9EV at f/2.8 - this will be visible in most scenes. The problem is still very pronounced at f/4 (@ ~1EV) but it's not overly significant anymore from f/5.6 onwards.
The Zeiss lens produced disappointing resolution figures in our MTF tests. The center performance is great straight from f/2.8 till about f/8. However, the borders/corners are rather soft at large apertures. They improve to good level at f/5.6 but the generally very good performance peak is not reached prior of f/8-f/11. This is very "late" for a prime lens and the figures aren't all that impressive.
Lateral Chromatic aberrations (color shadows at harsh contrast transitions) are low with below 1px on the average at the image borders. This is usually not field relevant anymore.
