The Makro-Planar is capable of producing distortion free images. This is impressive albeit quite typical for macro lenses.
The Zeiss lens has its share of vignetting problems when used on a full format camera. At 1.3EV @ f/2 the problem is fairly obvious but it's actually not worse than the results by its competitors at f/2.8. Stopping down reduces the issue and it's not field-relevant anymore from f/4 onwards.
The Zeiss lens produced superb resolution figures in our MTF lab. The center resolution is already exceedingly sharp at f/2 and the borders/corners follow on a very good level. The global peak performance is reached at f/5.6 with an excellent quality across the image frame. Diffraction effects have a higher impact from f/11 onwards but the quality is still very good at f/16 in the image center. Field curvature is a non-issue.
Chromatic aberrations (color shadows at harsh contrast transitions) are extremely well controlled and not field-relevant.
The bokeh (the quality of the out-of-focus blur) is a primary aspect for an ultra large aperture lens and the 100mm f/2 does not disappoint us here - mostly. The blur is very smooth and buttery. Out-of-focus highlights are rendered very well at f/2 and f/2.8 although the shape is not perfectly circular but a bit "cat's eye"-like (due to mechanical vignetting). If you stop down to f/4 and beyond you may spot some more angled highlight "discs" if you try hard enough.
Bokeh fringing at large aperture is a problem which is often not well corrected even by the very best lenses and the Makro-Planar is no exception to the rule unfortunately. If you have a look at the provided sample crops below you should be able to spot a purple halo in front of the focus zone and a green one beyond. The effect is clearly visible from f/2 till f/5.6, less so beyond.
